HID fog light Help
All things Altima Coupe.
nyykid725
Car: 2008 Nissan Altima Coupe 3.5 V6
Okay to start off this post I will tell you the entire process of what I did for my fog lights
I purchased a 3000K kit on ebay for my fog lights and installed everything correctly, then after installing them the bulb seems to be flickering, the light that was produced on the ground was flickering. So, I read on the forum that I should install a relay kit so i purchased one and me and my friend installed it to run it on the 3000K kit, so after installing the relay the bulbs will still flicker. So i figured maybe it was the entire kit itself, so I ended up buying a new kit with slim ballasts instead (Xentec 6000K H11 HID kit) as the other one were big ballasts (Xenon HID Lighting some really cheap kit), okay so thinking that the new 6000K kit with the new slim ballasts would not cause this problem after installation, it gave me the same flickering problem, even with the relay hooked up to it. I am really curious and simply agitated about this problem and I wish someone can post some responses to help me with this issue.
To also mention if this info might be any help, way back in 2009, a lady hit the front of the bumper on the altima coupe and it was sent to a body shop where they installed a new bumper and replaced my fog lights.
There is also an HID 6000K kit installed on my low beam headlights and i have no relays or no issues with that and it has been running perfect since i purchased it
It also seems to not flicker so much when the bulbs are turned on without them being in the fog light housing in the bumper, but the lights flicker when the are put in the housing, if this makes it any more helpful with the issue.
The fog light hids are also H11 bulbs, and its a 2008 Nissan Altima Coupe 3.5 V6
Please if there is anyone out there that can help me with this issue, i would much appreciate it
Thank You
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
Welcome to the club Nyykid!
NY I assume? Wherein?
It sounds like you are answering your own question here, but I dont know how its actually happening... Vibrations could cause the flicker possibly, does it flicker in the housing if the car is OFF?
It doesnt make sense IMO that a housing could cause an issue like this, but weirder things have happened!
35w kits?
nyykid725
yeh bro even with the car off and the push start on ACC or ON the lights still flicker
and it is a 35 W kit
i have no clue what the problem is
lol born in southside jamaica, queens
moved to FL about 2 years now
Mattv609
Car: 2009 Nissan Altima Coupe 3.5 SE V6 Azure Blue
its bad ballast... dont buy HID off of ebay.. i did that n had 2 replace the ballast 3 times and then it went bad again n guy stoped answering.... HIDGUY.net i order from there its legit sight warrenty and all n they brand new, ebay may say it but they deff not if i got bad ballasts... i have a 3.5 all HID n the ebay kit i bought same exact brand flickered on me n then got the 1s from HIDGUY.net they were perfect.
nyykid725
thanks matt i appreciate the advice bro, i will consider buying a new kit from the site you listed
one thing that i am also thinking is if it might be a vibration problem like Long Beach said
because the light still flickers with the car off but noticeably less
the light still does flicker with the car off
i will soon post a video to show exactly wat is happening just so it can be a little more clear
but i will definitely take your advice and buy a new kit really soon
and ebay kits are cheap and u do pay for wat u get, but sometimes the money is an issue lol
but thanks so much for replying to my post it was very helpful
hungs
Car: 10' 2.5s Altima Coupe Red
damn I hope mine doesn't flicker then. I just bought mine today from ddmtuning.com $40 bucks for the kit, most people here use and recommend them as well. good luck with your issue though.
nyykid725
thanks i am purchasing one from ddmtuning also hungs
i will test these out to see if they are a better quality
i decided on the ddmtuning because like u said alot of people recommend them
thanks
hungs
no problem, best of luck to you. btw I heard they have really bad customer service, so lets hope everything works out with the buy haha
nyykid725
what u think 55W or 35W for fog lights
im thinkin 35W
cuz i really dont wanna mess up and buy something that will flicker again
hungs
ive read its recommended to use the 35w for it since the 55w will run hotter which can possibly cause the fog lights to get too hot and melt
nyykid725
okay i settled on getting a kit from ddmtuning.com
its a 3000K 35W Slim Ballasts HID kit for the fogs
i paid $40 bucks
and i have my fingers crossed that when i install it, that it will solve my flickering issues
and i also bought their dual in dual out harness so we'll see
as for my ebay kit, well i guess i'll keep them in until i can replace it with the ddmtuning kit
and when i remove it, i will keep it as a nice reminder of how much trial and error i did for some simple little fog lights
thanks to everyone on this post for ur help
hungs
whats that dual in/out harness do? i didnt get it since i didnt know what it was for haha
nyykid725
btw the fog lights in my car right now are attached to a 40 amp relay and a 30 amp fuse
do u think that this is causing the flicker problem idk maybe if its too much or too little current
i bought the relay on ebay and it says it works for the headlight, i was also wondering if fog lights use a different relay for powering up the bulbs
http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWNX%3AIT
nyykid725
i think its just a relay its recommended for 55W kits
but i think that its usually if you have small gauge wires for ur lights
where it would take power straight from the battery, instead of using the oem harness to connect the ballasts too
its takes power from battery>ballasts>the powers the bulb
i think it will help idk, i just bought it anyways lol
p.s. correct me if im wrong anyone lol
hungs
ah ic, not sure if that relay would work or not. i'm still in the process of learning this stuff too
nyykid725
yeh same here i read ur post on the fog light insert
i wish i can help u on that but i really cant tell u anything really
have u thought about some halos for the fogs
cuz i've seen some really pretty altis with them
nyykid725
i have bought a $65 Zenex 6000K Slim Ballasts HID kit on Amazon.com for my headlights
since i have bought them never once have i had a problem with them
guess you really pay for wat u get
hungs
yea i actually did get some halo projector fog lights from spyder, they look really nice. havnt installed them yet since i dont have the inserts
nyykid725
oh okay i know what u mean by the inserts now
but still i wouldnt know where u could get them
check the dealership they shud have them only thing might be the price
or maybe eBay or craigslist or maybe someone on the forum have some for sale
DJ_B_Easy
Car: 2017 GMC Sierra All Terrain X
DDM Tuning is legit, I have 6K 35W slim ballast in my low beams and fog lights and never had an issue.
You dont need that relay.
nyykid725
im really excited and really anxious to see if this ddmtuning kit will work
because im so tired of taking off my bumper for ebay hid kits
i bought 3 kits already off ebay and they all have the same problem with the flickering even with a relay
i bought this one on ddmtuning and im waiting to see what happens
at one point i thought it might just be my oem connections, because a lady hit my front bumper and they re-did my bumper and the fog lights, so maybe the body shop put in some bad wiring for the fog lights
but all the ebay kits (3 kits total) all had this flicker problems, even big ballasts or slim it didnt matter it still flickered
i am also thinking maybe it might me a computer problem with the car idk, maybe an error code eliminator?
so im really looking into this because i wanna get my lights right one last time or else im just gonna go back to regular halogen bulbs
and also im wondering if the lack of an engine cover under my car can make the bumper vibrate even more
cuz the bodyshop did a half-a** job putting on back the bottom cover, and doing 100 mph on the highway made it fly off my car, so i ended up just taking it off, so im wondering if the engine cover on the bottom can help stabilize the bumper to not make it shake so much
but i doubt that has anything to do with it because the headlight dont flicker at all or vibrate but i just realized it isnt really attached to the bumper
but it was a $65 Zenex 6000K slim ballasts kit on amazon.com and since 4 months ago when i installed it it works perfectly never any problems
i guess there are alot of scams out there and ebay kits are there just for a cheap buy, and really a cheap but not a quality kit
-reply to let me know if im making any type of sense, or if im at least a fraction right about this
nyykid725
hey dj are u sure i wont need the relay
would u recommend it just to prevent the oem connector from burning out
im just curious
DJ_B_Easy
I dont have it in either of my DDM kits, I do not have any problems.
nyykid725
okay thanks
i bought it just in case i run into any problems
but i'll try first without it
hungs
just received an email from ddm about my order being shipped!! so excited to get them
nyykid725
thats great im still waiting for my email conformation
how long did it take for them to get back to u with the e-mail
anyways thanks for posting, let me know how it turns out when the lights are installed!
hungs
took about 4 days, either you should be getting an email today or tomorrow considering we ordered around the same day just different times. item is being shipped over from china =\ so maybe another week or so for it to finally come in.
nyykid725
yeh hungs im still waiting for the e-mail
i'm hoping that these lights work out fine
hungs
just an update tracking info says my lights is in san fran, CA
nyykid725
hey wats good bro
i got my order update email confirmation today from ddmtuning
u were right!
