DJ_B_Easy »
https://forums.nicoclub.com/dj-b-easy-u152144.html
Thu Jul 12, 2012 4:55 am
First thing i would check is to see if you hear the ballast (yes hear it) to make sure its actually getting power. Most aftermarket HID kits emit a little buzz, flip the switch in the cabin, get out and stick your head next to wherever the ballast is mounted, see what you hear. If nothing, then 1 of 2 things is probably wrong.
1) The polarity is reversed from the OEM harness to the aftermarket ballast. Happens all the time, in fact its almost expected from these aftermarket kits. All you need to do is rotate the plug 180 degrees and pop it back in.
2) Dude destroyed some OEM wiring. Through I dont see how he could unless he was a complete dolt.
Why didnt you just do it yourself? Where did you go and what did he install? If you cant figure it out hit me up and I might be able to come help.
