anotheraznguy wrote:the relay supplies enough power to light the hids. Without the Relay providing direct power, sometimes only 1 bulb will fire up unless you turn it on and off a few times. Hopefully that gives you a good explanation
TDot wrote:Ok, so your saying the factory harness isn't providing 12v to the fog? If so I guess I can understand that. I'll test it when I get a chance.
To add to what azn said, it provides 12v but not enough in a burst mode to fire the ballast. The ballast needs extra power for that initial startup 'kick'. The whole point of the harness is just more 'heavy duty'.
I was the same way initially...didn't get a harness because I figured I'd just plug each HID kit in to each light input. Needless to say, I am now running a harness on both my car and my sport bike. It's just better for the HID kit.
