I bought my 3K fogs from there, had the same issues. I now have the bi xenons from Mod Express and they are beautiful.McSteve wrote:I bought mine here xenon-hid-usa and someone on the forums was said he bought his there. I'm planning on getting an Optima Red top battery, so we will see if that resolves the issue. I also ordered some projector headlights of ebay, but they have H7s instead of the 9006 so I ordered some new bulbs, we'll see how that turns out. Maybe i'll post some pics
The flicker can mean lots of things. It usually mean that the bulbs aren't getting the proper starting voltage which can be caused by anything. Anything from thin wire which leaks out the energy and arcs on a closer ground. The terminals inside the bulb may be worn or just not getting enough power. I usually build a custom wire harness that hooks directly to the battery and uses a relay.McSteve wrote:well my I30 has two separate bulbs for high beam and low beam. I noticed that my left light flickers three times before going on, I never thought of blaming the ballast, it said in the instructions it had to do something with the battery. Maybe i should contact the company i bought them from.
I bought mine here http://xenon-hid-usa.com/default.aspx and someone on the forums was said he bought his there. I'm planning on getting an Optima Red top battery, so we will see if that resolves the issue. I also ordered some projector headlights of ebay, but they have H7s instead of the 9006 so I ordered some new bulbs, we'll see how that turns out. Maybe i'll post some pics
I would recommend Xenonplanet.com/shop for quality products. Our shops are well known in queens NY, and in Long Island NY for being wholesalers and importers of xenon HID kits. We actually use high quality kits from Banbo. If you interested take a look at our website for our november specials some kits are selling for 59.99 and 69.99. If your skeptical that our kits are good quality it is understandable. Our prices do raise questions. However these prices are true because there is no middle man, the importer is the retailer in this case. we also carry D2 RS coilovers for most makes and models of nissans. Please inspect our inventory for yourself at http://www.xenonplanet.com/shoptigersharkdude wrote:would you trust these peoplehttp://gothidkit.com/index.php...id=30feel free to give recommendations for other companys
