I did not repl the fuse. my kit is actually out of a bi-xenon system.I just did not install the projector assem. which has the hi/low door trap.the high beam ind'c.comes on when i move the stalk but headlamps shut of.I flick it back n forth so it strobes and ppl get outta my way(as if im hi beaming them).ChineseBuffet wrote:BenzTech Gone Versa: I'm just curious about your HID kit. When you installed your HIDs did you replace the OEM headlamp fuse to 20A? Did you have to attach any sort of extra relay cable that came with the HID kit for this to work on a Versa? Did you see any sort of high beam indicators light up on your gauge cluster after you did the conversion? I'm just wondering because you mentioned your kit was just a single Lo beam with no Hi. Thanks for your help.
CB
Why do people do this? It's actually really rude IMHO... but I'd like to hear the reasoning or an explanation behind it...BenzTech Gone Versa wrote:I flick it back n forth so it strobes and ppl get outta my way(as if im hi beaming them).
If you are in the Left lane, and either A) going slower than traffic, or B) pacing the person to your right causing a rolling road block. You deserve it.KimberKenobi wrote:
No need to replace the fuse, what you really should do is create a new harness which nobody does, because it is a P&P kit, but I will laugh when somebodies car ends up melting their harness causing a short, and possibly a fire.BenzTech Gone Versa wrote:I did not repl the fuse. my kit is actually out of a bi-xenon system.I just did not install the projector assem. which has the hi/low door trap.the high beam ind'c.comes on when i move the stalk but headlamps shut of.I flick it back n forth so it strobes and ppl get outta my way(as if im hi beaming them).
Stressing eyes how? I upgraded from factory HID to 6000k and road visibility is actually better. Now, if you go up to 8000k+ then I might agree with you that light output is not optimal.Clipsed wrote: and if you are using anything higher than 5000K you are stressing your eyes. OEM uses 4100K-4300K which nobody likes because it is not "BLUE ENOUGH" because everybody thinks it is yellow.
... I guess in my job I just see all the horrible things that go wrong when people do stupid things... Because it is kind of my job to write reports on all the people found guilty of felonies... so murders, reckless driving, wanton endangerment, and let's not forget the ever popular trafficking in controlled substances...Kolk1 wrote:If you are in the Left lane, and either A) going slower than traffic, or B) pacing the person to your right causing a rolling road block. You deserve it.
great article you linked to!pingflood wrote:Everybody considering getting an 'HID kit' should read this.
http://www.danielsternlighting....html
I have yet to see anybody present a convincing counter argument to Stern's article.
