KLL »
https://forums.nicoclub.com/kll-u124568.html
Wed Feb 18, 2009 11:53 pm
I have 98-99 pathfinder. It has 9004 bulbs. And it is the worst designed part of this car. I illuminates itself only. So i bought 9004 HID kit with halogen high bulbs on same bulb. When it is aligned lower than incandescent halogen bulbs, illuminates great. Even there is rain, it is ok. Its light color called 4300 kelvin(bright white). But.. If you turn on highs, halogens are completely put of focus point so still no high beams. Also when you flick, low turns of, so you need to use inverse relays and diodes to power lows when highs are on. Relays will get their trigger from corner lights.
