So, just chalk it up to an old car in the winter? Hmm...Hoffman5982 wrote:Pretty much all older cars run weird in the winter
OK well that will have to wait until the morning bc like I said it only does it after sitting for a while and I have been out in it already...badbob2121 wrote:Well you really haven't described this issue very well for us to understand. A fluctuating idle can be cause by many different issues. You should try and record a video of the problem and post it here so we can really see what is happening, and be as descriptive as possible...
This or check your plugs and timing. Chances are you have no emissions anymore and that can also account for some of the cold start issues.kouki munster wrote:A dirty/sticking iacv is the most likely culprit, but a coolant temp sensor that is starting to show its age is another possibility.
Nope! No more emissions, however, this morning during start-up I noticed a small puff of blue smoke which I know means oil... but I don't notice any blue smoke while driving or after warm-up or anything...OutToWinPAHC wrote:This or check your plugs and timing. Chances are you have no emissions anymore and that can also account for some of the cold start issues.kouki munster wrote:A dirty/sticking iacv is the most likely culprit, but a coolant temp sensor that is starting to show its age is another possibility.
Yes, old engine with 91k orig miles on it, with no head upgrade. The car sat for a while (6-8mos) before I bought it. So, is this a serious prob or what can I do to prevent these leaking valves? Could this be causing my fluctuating idle at cold start?biggie wrote:Old engine without any head upgrade? Normall for the valves to start leaking a little when it sits, that the normal cause of puff of smoke at start up.
Yeah, how would I adjust the valves? Yeah once it warms up it runs great! It's just on those cold start-upsbiggie wrote:Shouldn't be related to the idle at start up. Could try adjusting the valves, otherwise its not a big issue unless it gets to the point where it is smoking constantly (if you notice everytime you move from a stop it smokes).
My both of my KAs fluctuate idle at first start up, both NA and T, but I just let them warm up and don't pay it any attention.
kouki munster wrote:Adjusting the valves will not solve the smoking issue, to do that you will need to replace the valve stem seals. There is also not a whole lot you can do to adjust the valves on ka's with out the proper shims and tools to measure the clearance.
Wouldn't a vacuum leak b something that's constant? Not during startup? (just guessing)biggie wrote:Still sounds like dirty IACV and/or vaccum leak.
