non hicas by toreyki, on Flickr
your going to need a rear hicas bar and install that pump n res and your set1lazy40 wrote:Hello nico, my name is Torey im from Virginia beach Va and im in the process of turning my 91 super hicas s13 to a non hicas .I looked all over the forums and i cant seem to find a list of all the power steering parts i need, i need to know is what i have below every thing i need for the power steering to be non hicas ( Other then the pressure hose i already orderd that.
i think ima just weld the toe arms where they move in the rear hicas subframe after i swap the ps pump in , thanks manSullivanRacing06 wrote:your going to need a rear hicas bar and install that pump n res and your set1lazy40 wrote:Hello nico, my name is Torey im from Virginia beach Va and im in the process of turning my 91 super hicas s13 to a non hicas .I looked all over the forums and i cant seem to find a list of all the power steering parts i need, i need to know is what i have below every thing i need for the power steering to be non hicas ( Other then the pressure hose i already orderd that.
why would it not be a good idea to just weld it ? the hicas bar is like $180 and i can get it welded for freeEncryptshun wrote:Don't do that.
Either swap the entire subframe out with a non-hicas s13 (recommended) or get an eliminator bar. Either way, don't forget to pinch off/eliminate the lines going to the rear rack.
