float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Fri May 13, 2005 7:18 pm
It's actually Highly Intellegent Controlled Active Steering. And on the 91-93 USDM it was Super HICAS, which was basically the second generation of it. As youc ould guess, it was called Super Highly Intellegen Controlled Active Steering. As has been stated, it is a 4 wheel steering system. It is computer controlled. (unlike the 4WS system on the preludes) The degree of movement and direction are determined by input from the speed sensor and a steering angle sensor located in the steering column. From that information, the computer outputs a signal to actuators located on the underside of the car which control the amount of fluid that is forced into the rear steering rack, causing a flex in the rear suspension, causing the rear tires to move. Depending on the conditions, the rear wheels may point in the same direction as the front wheels, or in the opposite, or momentarily in the opposite, and then back to the same. I have personally owned a Super HICAS 240sx and I enjoyed it. I wouldn't recommend it for use in autocross as it can intiate in the middle of a turn and cause problems. As for everyday driving and ESPECIALLY on the highway, it's very nice and makes the car feel much more stable. It does have a slight learning curve to it.
