hicas steering
kansaschity
Car: 92 240sx
I was planning to swap in a hicas steering rack for a tad bit more responsiveness. I was told that you also have to use the hicas power steering pump along with it. My question is; When my SR goes into the car, will the usdm hicas power steering pump or sr20 pump work, or will I have to find a hicas power steering pump from an sr?
180fan
Car: 89 fastback
sr hicas
kansaschity
Car: 92 240sx
180fan wrote:sr hicas
will this be near impossible to find?
DriftFactory
Car: Evil S13
If you are lucky you'll be able to find an SR with the hicas pump. You may also want to post in classifieds as I'm sure most people that get one on their motor need the normal 2 hose pump.
180fan
Car: 89 fastback
either that or you could check with Marco Vargas. He's usually got some parted engines around.
kansaschity
Car: 92 240sx
180fan wrote:either that or you could check with Marco Vargas. He's usually got some parted engines around.
ok thanks, is that the guy from sr20store?
Axel Grungy
Car: 2001 G20 5spd
I think you need to scale down your sig a bit kansaschity^
