kevinphan »
https://forums.nicoclub.com/kevinphan-u97445.html
Tue Mar 09, 2010 8:39 pm
I removed it on mine and and got a HICAS bar, still have it brand new I repainted it yellow. You don't have toe arms in the rear like a normal subframe, instead you have tie rods. It's better to just swap subframes (which is what I ended up doing)
Swap PS pumps, new fluid reservoir. Remove the rack in the rear along with all the lines going from the engine bay, also on the passenger side fender wheel near the motor and you're good to go.
Let me know if you want the HICAS delete bar.
