maxnix »
https://forums.nicoclub.com/maxnix-u127.html
Sat Dec 30, 2006 11:14 am
Well, Infiniti dealer performed service history can be had from your local friendly Infiniti service writer. Or it can be read to you if you register it with Infiniti Customer Service as the new owner. A portion or all of it may be archived, so don't expect immediate retrieval. In any case, since you don't know, and evidently didn't do a pre purchase inspection, it is time to start one now. First thing to do is to change all fluids and filters. Plugs would be next (with valve cover gaskets if leaking), TB, EGR and IAC valve cleaning and plenum cleaning if it needs to come off. If it does, then under plenum hoses and KS and harness.
You can ohm test the KS through the harness and the injectors. Many articles here on how to do both.
