HICAS power steering
float_6969
Ok, so whats the consensus on whether or not you can use a HICAS CA p/s pump on a non-HICAS car? I'd much rather just use a non-HICAS pump, but they seem hard to come by. Can I use a FWD pump? I know they are on opposite sides of the motor, but maybe they mount the same? Any help would greatly be appreciated. Thanks!
Nismo1182
Car: Z06
I have a hicas pump on my CA in my non hicas coupe.
You just have to put a bolt in the 2nd housing outlet and remove the fins from the 2nd housing so pressure doesnt build up.
ride4lame
Nismo1182 wrote:I have a hicas pump on my CA in my non hicas coupe.
My sr pump is the same way. Unbolt the back, and you will see a whole bunch of little metal squares. Take them all out. Then plug up the outlet and you are god to go.
float_6969
And what about the bigger diameter resivoir opening on that pump? did you just use the HICAS resivoir?
Nismo1182
Car: Z06
I used my stock resevoir with a reducer piece for the hoses. Available at you local home depot, ace hardware or plumbing store.
float_6969
I wish I had a regular dang pump...
Trigger
who needs PS i dont and my car drives great....not hard to turn at all....although i am not a small guy that might have something to do with it
float_6969
guess I'm a wuss
Trigger
lol
