Wulfgang »
https://forums.nicoclub.com/wulfgang-u10889.html
Thu Dec 08, 2005 8:09 am
Pressure is regulated by separate valves located inside each port (front and rear). The pressure is probably the same or similar. However, there is a rather large difference in volume. The front impeller pumps far more fluid than the rear pump. That won't matter when you're driving down the interstate, but when you try to parallel park at Arby's, it might get a bit difficult to turn the wheel.
