HICAS Power Steering Lines
TeamTorqueJuggernaut
Car: 90 Nissan 240sx
I wanna know do the HICAS power steering lines work with an non hicas power steering pump and rack? Ive searched and didnt find a good answer
T-rev
compared to dohc lines? no, the hicas lines are different. You may be able to get them to fit, but I think the banjo fitting to the pump is 90 degrees the wrong way.
Yeah, the DOHC lines, I have a 90 so I'm trying to switch the lines over. I work at auto zone and pulled up the high pressures line for the two wheel steering and four wheel steering and they were both the same part number.
