HICAS Power Steering Leak
techtrader
I have a 1994 Infinity J30T and I have a Power Steering Fluid leak where the line meets the Fail Safe Valve. The line is rotted for about 3 inches. This is the line that goes over the axel and connects to the Rear Steering Rack. My Infinity dealer says the line is no longer available and I have to get one manufactured and oh by the way we have to leave your car on the hoist while you get this made at $100 per hour. They say it is a minimum 8 hour job to drop the rear sub frame to get at the line and do the repair. This assumes they don't break anything else in the process. So it will cost a minimum $1,000 to $1,500 plus the possibility of them having to replace the Fail Safe Valve if they can't work with it and any other issues that arise from this pain in the *** system.
I saw mention of a kit that can bypass the HICAS system. Does anybody actually know where to get this kit and will it lock the rear wheels?
Does anyone have a better remedy to this problem?
Thanks in advance
Linus Sagadore
maxhopper
Car: 02 Maxima SE 6spd
Moved to the correct sub forum.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
If anything is going to work its going to be a HICAS bypass kit for a 300ZX. I dont know if it will fit, because most of the time J30 owners dont have to bypass HICAS.
My recommendation would be to run from the infiniti dealer.
I have a friend in Dartmouth that may be able to recommend you someone who could do the job.
The infiniti dealer is wrong though, you can get the part. Unless of course you cant get it in Canada, which I'm sure wouldnt be a new feeling for you.
55750-11Y65 is the correct part number, im seeing $440 from http://www.infinitipartsusa.com, with an MSRP of $513US.
Is the hose rusted?
BTW, welcome to NICO!
driverdriver
Car: NICO's longtime resident Canuck!!!
Welcome to NICO!!!
The 300zx HICAS bypass kit works in J30. A number of members have installed it.
We have a member from your area(Elisha) who through the Nova Scotia/Maritime 300zx club(do a google search) found some very knowlegeable and helpful mechanics/enthusiasts in your area. As you may or may not the J30 and 300zx share many components.
Pick up the part you need from one of our sponsors get'er done.
Did you go to the dealer on Kempt road? When it was Steele owned dealer it was good, but ever since O'Regans took over the place has gone to !@#@%%
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
driverdriver wrote:Did you go to the dealer on Kempt road? When it was Steele owned dealer it was good, but ever since O'Regans took over the place has gone to !@#@%%
The parts guys are real nice and decent people at O'regans. The parts guys have no say and are mere employees that are fully controlled by the O'regans. O'regans as a family and business are bunch of low life thieves and are greedy little pigs and even sell parts over MSRP and will not hesitate to strip you clean of every dime you have. The service department personnel should be employed in the streets of Brooklyn shootin dice/ craps.
lino
techtrader wrote:I have a 1994 Infinity J30T and I have a Power Steering Fluid leak where the line meets the Fail Safe Valve. The line is rotted for about 3 inches. This is the line that goes over the axel and connects to the Rear Steering Rack. My Infinity dealer says the line is no longer available and I have to get one manufactured and oh by the way we have to leave your car on the hoist while you get this made at $100 per hour. They say it is a minimum 8 hour job to drop the rear sub frame to get at the line and do the repair. This assumes they don't break anything else in the process. So it will cost a minimum $1,000 to $1,500 plus the possibility of them having to replace the Fail Safe Valve if they can't work with it and any other issues that arise from this pain in the *** system.
Thanks in advance
Linus Sagadore
Keep us posted with your progress. Get the car out of O'regans and don't go there! Everybody's been burnt by O'regans at least once. Don't feel bad.
