HICAS power steering belt?
c-rad
Car: 1991 Nissan 240SX w/CA18DET
Is there a 4-rib belt I can get for my HICAS ps pump? I managed to get a hicas pump and crank pulley from Ryan (float), but I have no idea where to begin on the belt. As a last resort, I could always just use the standard 3-rib, on the 4-rib pulley, but I would prefer not to.
biosehnsucht
Look.
if you can get a 4pk840 you're good. If not, you can try ordering overseas or getting something close and see if you can make it fit via tensioner adjustment
c-rad
biosehnsucht wrote:Look.
Ahhh nice. Dude, I ALWAYS forget about your damn site! I just bookmarked it, lol.
c-rad
A Google search shows that it happens to be one of the belts used on the Jackson Racing Supercharger belts for Hondas/Acuras. The 4PK840 doesn't turn up too much. None of the parts stores allow 4PK or 3PK to show up as a search result.
biosehnsucht
yyeah those are gates or somesuch part #'sstupid parts stores use their own crap. you can try seeing if they have a cross reference option..
basically its 3pk or 4pk for 3 or 4 rib, and 840 is length (circumference) in mm
c-rad
biosehnsucht wrote:yyeah those are gates or somesuch part #'sstupid parts stores use their own crap. you can try seeing if they have a cross reference option..
Yeah, that or just get the CA18ET A/C compressor belt which is a 4PK845. I am sure the tensioner can make up for 5mm. But I will look for the 840mm first.
c-rad
Ok, well Advance Auto Parts sells the right belts-
Might want to add this to the crossover parts sticky--
HICAS Power Steering belt = 4PK0840Crossover = Dayco Poly Cog belt #5040330$15.48 as of 3/25/06
