HICAS?PLZ HELP
projectdrift240kid
Car: s13
I am new to this forum but i am on the 240sxforums but have got different opions on how to remove my hicas i have the hicas removal bar and i know i can take the relay fuse out to get rid of it but someone said I could not put a different steering wheel (racing) idk wat to believe any help would be very helpful and appreciated
livinglegend2100
it depends. there is either HICAS which is hydraulic, or SUPERHICAS which is electronic.
the OPTIMAL way to remove it, is to replace the entire rear subframe with one from a non-HICAS equipped car.
But the eliminator bar works as well.
YOu can run whatever steering wheel you want. doesnt matter. the only thing you are going to lose by going with an aftermarket steering wheel are either, cruise control, air bag, horn, or radio controls (when applicable)
projectdrift240kid
Car: s13
its the superhicas but does that mean all i have to do is remove the fuse and steering wheel to aftermarket and i should be good?
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
Why would you have to replace the steering wheel, just give me the logic on that, I need a chuckle.
Remove the fuse, put it the hicas eliminator kit, and go. The steering wheel would have absolutely nothing to do with the Hicas...
AND SEARCH... This has been covered more than enough times to know exactly what to do if you search "hicas elimination" alot of information comes up.
vajay240sx
Car: 1992 Nissan 240sx se / 1995 nissan 240sx
thats why i didnt go with one...i find no need for it. se is good enough for me. no need to waste extra time and money
Firewind
Car: 240SX
YOU DO NOT NEED TO REPLACE THE STEERING WHEEL! Who ever told you that, doesn't know anything about 240SX and you should never listen to their advice again.
Also I agree the best way to get rid of HICAS system is swapping the the entire rear sub-frame with one from a non-HICAS 240sx. It's not as hard as it sounds.
Removing the fuse will disable the HICAS system, however the HICAS adjusts your toe angle, so it could slip out of alignment every so often.
Using the cheap locking bars you find on ebay and what not will lock it in place and keep the hicas system from moving. However you will not be able to adjust your toe correctly.
There are Hicas locking systems that cost a lot more, say $1300 is usually what I see, and they do allow you to adjust the toe angle for realignment or custom alignment, however for the cost it's not worth it.
sean@z1
Car: 1993 240sx
If your HICAS is driven by the PS pump you will see two lines. You can use the same pump and block the HICAS like the RB20 guys do by opening the back of the pump and removing the metal plates inside that form a star shape. Followed by Welding up the rear banjo bolt. Or you can replace it with a NON HICAS pump. Then your Sub-frame you can remove the HICAS rack and place a HICAS elimination bar on it. OR replace the whole Sub-frame. As far as the steering wheel I have never heard of that at all. I had a Hicas hatch and first thing was a MOMO steering wheel.
Modified by sean@z1 at 11:02 AM 6/22/2009
projectdrift240kid
Car: s13
the hicas is controlled in the steering wheel but thats not why im doin a different one i just want one i didn't say that so my bad but if u just put the aftermarket sw on then u have a lighter sw to have fun with
Ajax
Car: 1991 240sx SE
2010 Mazda 5
Lighter steering wheel?..I eliminated my HICAS and replaced my steering wheel. Make sure you get the correct hub adaptor- its the same as the HICAS Z32 steering adaptor IIRC. Otherwise, you will not have a working horn- I hate not having a working horn.
blacksrjdm
projectdrift240kid wrote:the hicas is controlled in the steering wheel but thats not why im doin a different one i just want one i didn't say that so my bad but if u just put the aftermarket sw on then u have a lighter sw to have fun with
Uhhhhh, yes you did pal...
projectdrift240kid wrote:its the superhicas but does that mean all i have to do is remove the fuse and steering wheel to aftermarket and i should be good?
No worries though, we wont hold it against ya yet. Just make sure you search in the future, will save alot of hassle, flaming and misinformation.
Modified by blacksrjdm at 12:11 PM 6/22/2009
fiznowler
Car: 97 240sx se, 5 speed, paint, tan leather interior. vg30dett swap in progress.
86 300zx NA Daily Driver
Too many other nissans and parts to list!
projectdrift240kid wrote:I am new to this forum but i am on the 240sxforums but have got different opions on how to remove my hicas i have the hicas removal bar and i know i can take the relay fuse out to get rid of it but someone said I could not put a different steering wheel (racing) idk wat to believe any help would be very helpful and appreciated
I don't see how anyone could read this crap. Both of your posts are illegible. These aren't even wrote at the 3rd grade level. You could at least attempt to use a little punctuation if you can't spell. I am surprised anyone even attempted to help you.
blacksrjdm
No offense, but if you are going to school someone on their grammar and typing skills, then use proper grammar and punctuation yourself. The proper word to use there would have been "written".
fiznowler
i is sorrry tht i didd mrs tht 1 i has a 240 i can drfft tho an i donnt eva srch and jst type stuppidd s***t to make furoms fullz off s***t to read my lit ter stearing wheel mak me trun fasterr though so i can git reel slidewayz!
I figured this s*** out now!
blacksrjdm
fiznowler wrote:i is sorrry tht i didd mrs tht 1 i has a 240 i can drfft tho an i donnt eva srch and jst type stuppidd s***t to make furoms fullz off s***t to read my lit ter stearing wheel mak me trun fasterr though so i can git reel slidewayz!
Ok, thats just a little juvinile.
AZ89two4Tsx
El Pollo Loco has good chicken. You should try it sometime.
Uberck
Car: 240sx
if you dont have a lift and airtools replacing a subframe isn't exactly "not as hard as it sounds". if you can get access to a garage and do swap out the subframe i'd suggest replacing your driveshaft, hubs and calipers to non abs and remove the abs pump. will make life easier down the road
fiznowler
I think it is juvenile.
Modified by fiznowler at 1:21 PM 6/22/2009
vajay240sx
LMFAO!
