Hicas Lsd
slideways92
Car: 1992 nissan 240sx se super hicas
So i have noticed my right tire is now bald no idea why Any ways is there any why to rebuild this or would it be cheaper to find a j30 lsd?
slideways92
By the way its a hicas 92 240sx se
TroubleBound
Car: 1992 240SX Hatch
dont know exactly what you mean or much about cars really, but ive seen this around would one of these help?
HICAS Cancel Bar
The Kazama Auto HICAS Stopper Rod eliminates the rear suspension system that can independently toe in/out the rear of HICAS equipped Nissan 240SX. On certain models of the Nissan 240SX S13 and S14, HICAS was an option that altered the toe angle of the rear under various loads. This could cause some instability and inconsistency in the car's handling, therefore it is most popular to eliminate this function.
or any HICAS elimination car that was just an example...good luck HICAS sounds like a b*tch
2fast4urass
can you put hicas on a regular 240sx
Razi
Car: Moo
With a ton of work yes, but why would you?
2fast4urass
I want HICAS on a regular s13 hatch cause it helps hug around turns and prevents sliding and keeps you straight on drags depending on how it's setup where the rear wheels turn with the front wheels or opposite of them
what would i need to put it on
Razi
Car: Moo
I'm sure you can get better results with a well setup car without Hicas.Hicas adds extra weight, it's going to hinder your performance.
AZ89two4Tsx
I'd take some coils over stock suspension + hicas any day.
Btw, can you even use coils with hicas?
Razi
Car: Moo
No.It's designed to work at stock height, getting lowered is going screw it up.
slideways92
Crap i have a 92se hatch with hicas i was told that you can lower it? And coilovers will work? This is gonna be a problem because i am about to get some stance coils do i need to swap out the subframe for a non hicas before they will fit also power steering pump?
TLP_280ZX
Car: 89 240SX
i have HICAS LSD and im on coils. dont have any probs.
