HICAS Light
red coupe89
Car: 1991 Fairlady Z
2005 Nismo Frontier 6spd 4x4
2000 Honda shadow ACE 1200
hey everyonce, followed a few different DIY to decode the HICAS light on my 91 Z32 but to no avail. from the moment I turn my car on the light is red the entire time. some times on an on ramp the car will turn harder for a moment while the wheel is at the same position threw the cornor. is there anything in particular I need to look for or if there is a better DIY for decoding the light.
any help would be great,
thanks!!!
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
Have you checked your power steering fluid?
red coupe89
yea fluid is at the full line when running.
robomatic12
Car: 1990 300ZX TT
Check it when the car isn't running
BigTDogg (MA)
^ what he said. Shut the car off and let it sit for 5-10 minutes (better to do it after sitting over night). Check level, if low, fill with ATF (not PS fluid). Start and check light. If that doesn't work, you'll need to do the HICAS diagnostics.
red coupe89
yep its at the full level when bone cold as well. i tried to get it to enter diag mode and cant do it, ive found 2 different ways as well, neither worked.
thanks
