Hicas in s13? quick question
AnotherSRLemming
Yes, I have tried using the search option.
Several people have mentioned that s13's with ABS also have HICAS. I have ABS. Does this mean that I have HICAS as well?
ss240
it does not mean you have hicas as well. if you have the words SUPER HICAS running along the side of your S13 then you probably do...
not all ABS S13's have HICAS as well.... i don't think
wickedpelf
Car: 1991 240sx with super hicas
well the quickest way to tell if u have hicas is look at where your rear wiper controls are(assuming u have a hatchback, if not look to the right of you rear defrost button) is u see a black rectangle with a pinkish lookin oval that says "HICAS" you have it...i do :)
SeVa-S13
Car: '05 GTO 6spd
Or just look at the trim line along the bottom part of your quarter panel in front of the rear wheels. It should scream "SUPER FREAKING HICAS." If not, then don't bet on it. ;)
coola
I think the best way would be to look under your car for the power steering rack behind your diff. and you either got it or ya don't.
SilviaS14KA24DE
Car: Doriftu
no, the best wa is like seva said, it'd say "I'M USING SUPER HICAS BIZNATCH" in big white outlined words and what wicked said. Why bother to make your knees dirty when it says it right there?
