hicas 240s have doffrent gas tanks
roadboy240sx
Car: I like Nissans
ok so the fuel baffel broke lose in the tank on my car and im trying to replace it with the tank from my parts car. mine is a 91 hatch and my parts car is a 91 hatch hicas. but the filler neck just dosent want to line up. i tried swaping the necks out and still nothing anybody know anything about this. thought all s13s had the same tank?
i had the tanks side by side and they looked to be the same, i cant say i was looking for diffrences. and the parts car was hit really hard in the right rear. i dont think that would make a diffrence tho.
Modified by roadboy240sx at 11:39 AM 10/7/2009
roadboy240sx
Car: I like Nissans
well i just went out and pulled the tank out again and yep they are diffrent where the filler neck bolts on is on less of an angle than the standered one. why it still wont fit with the filler necks swaped idk. oh well im F-ed
hotrod240sx
Car: 1991 Nissan 240sx SE Hatchback with Hicas
it should be alot easier to find that tank in a junk yard than the hicus. although i do know that alot of junk yards will puncture the tanks to drain them when processing them i know where 2 or 3 good 1's here are though, or pretty sure there good. thanks for the info that the hicus tanks are different though cause my 240 is hicus and i will chalk that to another difference between it and the reg, and i another part if i needed to replace would be a pain.
pidass
Car: 92 240SX Hatch
how did you get the tank to drop completely, I'm leaking gas from where the filler neck meets the tank (I'm guessing worn o-ring)?
I undid the straps and fuel pump harness but the tank would only drop like 2-3 inches. Thanks!
hotrod240sx
have you pulled the cover and undone the fuellines i have seen people do that before and wonder why the tank would drop. not trying to call stupid eventhough i know it may sound that way, but i know sometimes obvious stuff can be forgotton
roadboy240sx
Car: I like Nissans
hotrod240sx wrote:it should be alot easier to find that tank in a junk yard than the hicus. although i do know that alot of junk yards will puncture the tanks to drain them when processing them i know where 2 or 3 good 1's here are though, or pretty sure there good. thanks for the info that the hicus tanks are different though cause my 240 is hicus and i will chalk that to another difference between it and the reg, and i another part if i needed to replace would be a pain.
i own all the 240s in the area lol ( for real tho) and i have called every junkyard around no one has one, i got an idea and i hope its gonna work. ill post it up if it dose, oh and a new tank from the dealer is $382.
pidass wrote:how did you get the tank to drop completely, I'm leaking gas from where the filler neck meets the tank (I'm guessing worn o-ring)?
there is a bolt that holds the filler neck to the car its self its all the way at the top. take right rear wheel off and remove the plastic guard youll see it. and make sure before you drop it all the way check to see you have disconeted all the lines. there are 3 lines ones the sending line one is the return and one is the vapor .line DONT get them mixed up do those things and you should be good to go:1 also more than likely your filler neck is rusted out on the bottom or you have a split line some where. mine had a split in the overflow return line from the filler nick. hope i helped
pidass
Car: 92 240SX Hatch
that bolt must be it, do I have to remove the fuel lines just to drop the tank? I don't want to completely remove it from the car, just enough to get to all the bolts that hold the filler neck to the tank.
In my adventure of trying to drop it last week I was able to pull back the fuel tank protective plastic piece and was able to see the stains where the fuel was leaking out of one side of that connection. I was able to reach 2 of the bolt and tightened them a little, which has helped most of all the leaking fuel but I still smell gas and there doesn't seem to be pressure in the tank when I open it.
sorry for the off-topic and thanks for your experience!
roadboy240sx
Car: I like Nissans
pidass wrote:that bolt must be it, do I have to remove the fuel lines just to drop the tank? I don't want to completely remove it from the car, just enough to get to all the bolts that hold the filler neck to the tank.
you dont half to. just make sure you have the tank well proped up by something. and while your at it and have the tank lowerd i would check the filler neck for holes. and check all the lines coming from the tank and fuel pump for splits or cracks. also check the rubber overflow line for splits and cracks. if you give me some time later to night ill postup some pics in this thread so you can see every thing.
pidass
Car: 92 240SX Hatch
awesome, I would greatly appreciate it. I probably won't be doing it for a couple days anyways, I gotta burn all the gas out of the tank again.
