Okay, here's the deal. I have both the Koni Sport and KYB GRX struts sitting on my desk right in front of me. The lower mount is not the same.
1) The bolt bushing is 20mm I.D. and it is 22mm on the Koni. So I guess the question is, which diameter bolt is used on the stock HICAS hub? That's a heck of a difference in slop right there.
2) The bolt bushing is also longer (taller) on the KBY by 2mm which would add even more slop for the Koni when bolted up or the KYB would be a force fit in the bracket.
3) the bolt bushing on the KYB is not centered in the lower mount. It is offset by about 10mm lower to the bottom of the mount.
I have not seen the rear knuckle and mount on this car to see how that would affect the fitment. Based only on the bolt O.D. alone, I would say it does not look like a direct fit. I think that is what the folks at KYB were trying to say. If the car uses a 20mm bolt like the KYB, that thing is going to rattle around in the bushing like crazy using the Koni. If it uses the larger 22mm like the Koni, using the smaller 20mm is going to rattle around in the hub holes. Does anyone have the bolt size listed for the HICAS hub? That would give you the answer. I don't see where this is a direct fit without messing with the holes in the hub or bushings or both.
