the only adjustment i have is that the seatback itself is adjustable...otherwise i see absolutely no adjustments in the seatbelt system. the seatbelt guide on the seatback near my left ear does not move at all and neither does the seat belt holder on the B pillar (except that it swivels back and forth...rydwhite wrote:You guys are talking about the same thing. It is just that one arm that either folds/pivots down or up. There isn't any more adjustment than that though.
Exactly. It swivels down out of the way so people can get in the back and it swivels up. It doesn't have to be up to be used. By swiveling it up, it locks there. That makes the seat belt a little higher than if you leave down. That's all it is. Not much. Maybe an inch. It is a pain in the *** to leave down anyway because it is so freakin' hard to reach.redhed wrote:
well, the original poster was complaining about the seatbelt being uncomfortable. i have the same issue as the seatbelt likes to rub on my neck near my shoulder (i'm 6'1"). and there really is no way to adjust for this. the only thing i've found that does work a little is to take the seatbelt out of the guide on the seatback. but you are not supposed to do that. so i usually just occasionally push the belt toward the window to make it relax a little...rydwhite wrote:
