Hi! New member here with a few questions.
Nissan 350z / Nissan 370z general community discussion forum
Hans
Car: 2003 Nissan 350z Touring
Hi - I just bought a 2003 350z Touring 6spd the other day, and its pretty cool so far. It's taking a little getting used to with the visibility and gearbox and all, but I'm enjoying it.
But I hear a deep osciallating noise that changes based on speed, kinda like a tire noise, although I'm not sure if it happens at all speeds or just low speeds because of ambient road noise.. It happens with or without braking too so I dont think its the pads or rotors or anything. Could this be an indication of uneven tire wear? Or should I not really worry about it? Also, my driveway is on a sorta steep hill, like 30 degrees. I parked it tonight and with the parking brake on and the car in neutral, it rolled backwards down the hill almost as if the brake wasnt on at all. But when I put it into first it stayed put. I'm fairly sure although not certain that I had the brake all the way up when I parked it in neutral. Thanks
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
Welcome to Nico!the noise could be the typical tire wear, might be worth a stop by the dealer to be sure it's nothing mechanical, as for the e-brake, did you pull it enough? could you get another click out of it? when parking on a steep grade you should pull the parking brake and leave it in gear as well, if it's terribly steep I'd find a more level spot to park, manual cars on steep grdes make me paranoid, with an auto you have a positive locking pawl taht engages the output shaft with a parking brake you pull strail on a steel cable and hope it doesn't stretch any
Bubba1
2024 Honda HR-V
2008 Toyota Corolla S
2001 Toyota Avalon XLS
evildky wrote:Welcome to Nico!the noise could be the typical tire wear, might be worth a stop by the dealer to be sure it's nothing mechanical, as for the e-brake, did you pull it enough? could you get another click out of it? when parking on a steep grade you should pull the parking brake and leave it in gear as well, if it's terribly steep I'd find a more level spot to park, manual cars on steep grdes make me paranoid, with an auto you have a positive locking pawl taht engages the output shaft with a parking brake you pull strail on a steel cable and hope it doesn't stretch any
Welcome. evildky's right on all counts. the OEM Bridgestones on the 03 are a bit noisy to begin with. I noticed my original set got louder as they wore down. If you notice some feathering wear on your front tires, Nissan had sent out a notice to 03 owners to bring the car into the dealer to correct it.
As far as parking on incline with any manual transmission car, it's always best to leave it in gear with the engine off in addition to the e-brake. I actually go a step more and leave it in a gear in the opposite direction of the incline. for example, if the nose is downhill, I leave it in reverse.
Enjoy your Z. They're a lotta fun.
nsrZ32
Car: 90 Nissan 300ZX TT
78 Datsun 280Z
71 Datsun 521 Pickup
98 Nissan Sentra 2.0 SE
02 Nissan Altima 3.5 SE
01 Ford Focus S2
Welcome to NICO!
Enjoy the Z and put up some pictures for us
350zlcrj
Car: 2006 bmw
Hi,
I just bought an 06 350z enthusiast last weekend. Damn! thats a real sports car!..my question is it comes with 18's. Can i put in 18 (f) and 19 (r) like touring model. Will it affect my suspension?
any info would help!
cris
evildky
06 Nissan 350Z GT
yes you can run a staggered wheels, and so long as the offset is correct it won't hurt anything except ride quality due to the shorter sidewalls
Hans
here is the only pic i have atm taken with my camera phone from my bedroom window. ill take some higher quality ones this week.
whiterps13
Car: white LE hatch
Welcome man, I cant wait to see pictures fo your car. BTW, the one you posted doesnt work.
evildky
06 Nissan 350Z GT
attack of the red x where are you hosting your pic?
Return to “350z / 370z Discussion”
