RemixZ »
https://forums.nicoclub.com/remixz-u77781.html
Wed Jan 27, 2010 10:23 am
Rock on your purchase! First thing first in this order; buy a BlaZtII/software cable, up your timing by 2 and get some #6 cold sparkplugs... then go CAI, Plenum Spacer, Testpipes/Ypipe, sway bars, suspension lower that beast!, then get nitrous or fi! In that order Im installing the test/ypipes...
I got a used '03 Touring last summer. It has the 3rd gear issue too.. kind like my '90 z32 woa whats new... As with my z32 I replaced the transmission oil with Redline M90...Though it didn't work as well as it did on my z32, it sure helped. I still on occasion grind when quick shifting from 2nd to 3rd... or when downshifting to go faster from 4th to 3rd... But overall the new oil and reving up helps...
Also, while your at it change the transaxle (differential) fluid too...I used redline gl5... But, whatever you do don't put gl4 grade(the m90) into your diff... Why? something to do with the teeth or gears... I forgot....
Oh and FYI: I use for my engine - AMSOIL 0/30
Post some pics!!
