Hi! {New 300zx Owner}
overwest
Car: 2001 Nissan Pathfinder [Project Pathgrinder] RIP
1990 300ZX TT [PikachuZ] RIP
Hey guys, I'm new to this section of the forums. I'd spend more time over on NPORA or in the R50 section when I had my pathy. But life happens and I was able to replace with this beaut, TT 1990. 200k on the ODO.
Lemme know what things I should look out for right off the bat. I know it'll need an alignment first, and I saw some rust buildup on the exhaust piping.
This is the first time I've owned a boosted car, my first car was an 81' Corolla TE72 Liftback with like...50hp :P
And my Pathfinder was the LE 3.5 with 250 stock. All I had on it was a Flowmaster and a K&N Filter. But this car seems much, much faster aha. I try not to push it too hard because of the mileage. I'm going to UTI here in AZ in two weeks so I'm not trying to end up blowing a bunch of money swapping parts off the bat.
twinturbozxtacy
Car: 91 tt
do a tune up, fuel filter, plugs, air filter, injector cleaner etc... then if you do not have records of service dates id look into the timing belt and components, trans fluid and diff fluid. maybe pads and any old bushings if yo want to be real anal. otherwise enjoy it until the motor wears out.
z32loverboy
Car: 1990 300zx CRP N/A 5 Speed (wreaked, now a shell) SOLD
1993 Slicktop CRP N/A 5 Speed w/ '90 built N/A motor and interior
1958 Ford f-100 straight-body (Grandaddies truck, resto-project)
THIS^ Do all the maint at once and save yourself the hassle of tearing into it more than once!
SleeperPower
Car: '90 Nissan 300zx Twin Turbo
I recommend not throwing in any injector cleaner if you still have the old style injectors (Model years 90-93). I don't think the new style injectors even need any cleaner.
http://maxima.theowensfamily.com/tsb/NTB94-002.pdf
Good looking car and welcome!
nissanfreak12
Car: 92 300zx 2+2 TT
Welcome! You should check out projectz32.com, they are local in AZ, bunch of great guys over there. Enjoy the boost!
nexus08
Car: 1990 300ZX NA
Welcome! Nice car!
300ZXttZMAN
Welcome to NICO!
+1 on the maintenance!
What are your plans for the car?
overwest
Thanks for all the friendly welcomes into the z32 section guys aha. Knew I'd be gladly welcomed no matter where in the NicoClub forums I went. Definitely will add the maintenance to the list of things to do. As to what I have in plan, aha. First I need a job.
BUT.
lol. In order I've got.
+ Tuneup (Plugs, belts, fluids)
+ Wheel bearings? (At certain speeds the ride gets very choppy like the engine is cutting out.)
+ Alignment
+ New color matched bumper
+ Alarm system
+ Dual Flowmaster 40's (I've got one leftover from my Pathfinder in the closet)
+ Detachable wheel/tow hook/ "mad jdm" stuff (okay maybe not so much aha.)
+ A proper wheel setup that isn't ridiculous
+ Coilovers.
+Depending on the engine condition this point, i'll start jumping into engine performance but I'll see.
z32loverboy
I would also look into the injectors. Take a multimeter to em and check the OHMs on them. they go out quite a bit. Also I would check your PTU and see if it's the old style one. Other than what you've covered do you know when your timing belt got changed last?
overwest
Sorry about the delay, keep forgetting about my thread. School and such. But that definitely sounds like a good idea, once I start tearing into it I'll take a look at that, UTI did give us these fancy multimeter deals.
Here's an update for you guys, got some new shoes on Yella' Bird, super ridiculous offset. Aggressive.
helio300zx
Car: 300zx Twin turbo
what kind of wheels are those? it looks thinner then stock 8.5 on the rear?
Ziggy1621
Car: '90 Z32 TT (Shibui)
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
Welcome! And another word of advice... Clean and pamper her so she treats you well ;)
300ZXttZMAN
Looks nice!
