HI IM NEW AND MY GIRL IS HAVING PROBLEMS WITH HER 2003 ALTIMA
PROBLEMEDINFINITIQ45
Car: 1995 INFINITI Q45
FIRST WHEN IT STARTS IT BUMPS I ALSO HEAR NOISE COMING FROM THE BACK ENDAND FROM TIME TO TIME IT BUMPS WHEN YOU DRIVE ITTODAY ON HER WAY TO WORK IT WAS BUMPING BAD AND THE CHECK LIGHT IS ON NOW WHAT CAN I DO
marlin29311
Car: 2008 Infiniti G35x
YOU DON'T NEED ALL CAPS.
What do you mean by bump? Does the car bounce up and down? Or is there a noise?
If your engine light is on, take it to an autozone or something and have them run the OBDII scanner to get the light code for you - post it back up here and hopefully we can help!
kerrton
Car: 2008 Nissan Rogue SL FWD Gotham Gray
Yeah I have no idea what "bumps" means - the best strategy to get real help from this forum is to post really detailed description of the problem you're having. I know it's hard to describe sometime, but you need to include lots of details about the circumstances under which things occur such as how long after starting up, how fast, how much throttle or brake, and details of the sound or feeling that is cause for concern.
However, if her check engine light is on she should not be driving the car, that is basic stuff, if you drive with the check engine light on you're crazy, get that car to a service department before she does major damage to that car!!
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
marlin29311 wrote:If your engine light is on, take it to an autozone or something and have them run the OBDII scanner to get the light code for you - post it back up here and hopefully we can help!
OK I CHANGED THE SPARK PLUGS AND IT STOPED IT WAS A MISFIRE
CPS
How many miles are on the car? What kind of plugs did you use?
mcheddadi
Car: R8
PROBLEMEDINFINITIQ45 wrote:OK I CHANGED THE SPARK PLUGS AND IT STOPED IT WAS A MISFIRE
HI I'M A GIRL, GLAD IT WORKED FOR YOU KTHXBAI.
Rob.Vegan
Car: 08 2.5S Altima Coupe 76 Datsun 280z (not running)
mcheddadi wrote:
HI I'M A GIRL
Mehdi, stop switiching genders on us
surmanm
Car: 2008 nissan altima coupe 3.5 se
gender changing oh s***..... whats the going rate these days
toxik
Car: 09 Pearl White 370z
what a 8==D
surmanm
toxik wrote:what a 8==D
A big 8=========D
toxik
haha i was hoping for that reply lol
