ryanwynnyk wrote:1. Where is the fuel filter located?
Passenger side, at about where #2 (front) spark plug is. It's a 2" diameter silver can. You can't miss it.
ryanwynnyk wrote:2. The drivers side door window does not open and the drivers side door doesn't unlock with the remote.
The window not rolling up could be the power window amplifier located in the door panel, a problem with the regulator/motor (burned up), or the cable has come off the tracks. If you can get the window fully down you should be able to see the pulley for the cable and see if its come off the tracks.
If the door unlocks with the key and not the remote it's probably the door lock actuator (in the door) but it may also be a broken plastic clip on one of the many rods. Is the door lock bar on the DF door locking all 4 doors?
All these parts can be had used for a reasonable price in the parts forum. You could also do a self-diagnosis following the steps in the FSM. It should lead you to the problem.
ryanwynnyk wrote:3. Will I enjoy this car?
If you can afford to invest a few $$ to get her running right you're going to enjoy the heck out of it. It's an amazing car, especially the 94-95 with all the upgrades from the 90-93. Careful in the snow though. Enjoy.
