Hi, I'm new, and I need some help
penguindrummer
Car: 1993 Nissan 240sx
I just got my car, and its a 93 Nissan 240sx, and everytime I turn the car, it shakes like crazy. Can anyone help me figure out what the problem might be?
goodsx95
Car: 1993 nissan 240sx
what's it idling at?
BlackZenki82
Car: 1991 Nissan Skyline GTR
power steering pump locked up? causing too much drag on the belt... might want to check that out...
or you can try better describing the problem...it just shaking when you turn is a bit general, what shakes, how does it shake, do you know where it's coming from? engine? suspension?
MastaYu
Car: 92 Nissan 240SX SE HB
Welcome! Hope you figure out what's wrong with it
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
is the engine modified?...like high compression?..do you have racing motermounts?...has the suspention been modified for stifness?...there is lots of stuff that can make a ride shake..give us some details sire.
goodsx95
OOPs. mis-read that. thought you said when you you turned it on, not turning in general. Do you hear any odd noise when turning? could be something as simple as tire rub if you have aftermarket wheels. Or it could be something more complex like rack and pinion or bent control arm.
