M4T5 »
https://forums.nicoclub.com/m4t5-u123303.html
Sat Feb 28, 2009 8:39 am
Dont even bother trying to do that. For one, you will not find what you are looking for in a bolt-on kit. No one makes them.The other reason I would strongly be against this if you went the fabrication route would be possibly losing power. Almost every thing you do to this car will require the ECU to be retuned for the change you inflicted upon the M45's engine performance.
With that being said, finding someone to tune this car will not be easy at all.There are supposedly only two known tuners (to my knowledge) that can tune this car. One is UpRev in TX and the other is Stillen in CA.Be careful with what modifications you do to this car. It could be a big mistake and net you power loss. If the change is easily reversible, then by all means give it a try, but you were warned. This is your warning!
J
