Hi Flow cat for HS headers?
fritts
I was wondering if anyone sells a high flow cat for the HS headers with an O2 bung for an S14. I would like to just lengthen the wire to the O2 sensor.
Aries
Car: LT1 240SS
several companies sell high flow cats with O2 bungs in them.
fritts
Do you have sites for them. I know of random tech. but from what I have seen they do not include an o2 bung.
LiU
Car: Cars
catco and random tech both sell high flow cats, but I believe the catco one is cheaper (at enjukuracing.com). I don't think either of them come w/ 02 bungs but you can drill a hole behind the cat if you want.
Exar-Kun
Car: 2005 350Z
random tech cats should have the sensor bung in them.-chet
Scott McLellan
O2 bungs are like $10 and you can buy them from most sites that sell high flow cats. They are simple weld-ins. The only thing that I have against the catco from Enjuku is that it is 2.5" or 2.25" can't remember now and the hotshot you are using has a collector size of 3". This wouldn't be a huge problem or anything but it would still be a small restriction because of the "step". It does have the advantage of being custom fit so it will bolt right in though. Another company I thought of was Dynomax.
Exar-Kun
Car: 2005 350Z
hotshot headers end in a 2.5" pipe and flange.-chet
Scott McLellan
okay. sorry for posting incorrect info, but that's just what somebody from Enjuku told me when I asked them specifically about this.
Exar-Kun
Car: 2005 350Z
yeah, the onyl reason I know is because m 80mm/3" test pipe flange was too large for it and it caused a small exhaust leak..-chet
Scott McLellan
80mm is actually like 4 mm bigger than 3 inch, but yeah you're probly right. by the way, where do you get gaskets w/ only 2 holes that big? -scotty
Exar-Kun
Car: 2005 350Z
i hate to say it, but NOPI has them...you can ask the guys at heavy throttle, or phase-2..they should be able to get them or tell you where..I had some laying around from my 300ZXs exhaust.
-chet
Spade
Car: Cars
I just purchase a High flow cat with O2 bung from this seller on EBay. Its a company that sells on Ebay all the time, have had a few friends buy from this guy. Its a weld in Cat but heck, my local muffler guy said 20 bux and its in.
I paid 51.50 shipped for a 2.5" with 1 O2 bung.
http://cgi.ebay.com/ebaymotors...33636
