Hi everyone
fixedf50
Newbie here planning on picking up an infiniti f50 anything I should look out for? I been debating on weather to get an 02 or an 04 any major different?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Yes get the 04 because its newer and it has the updated ECU software which means its quicker than the 02 unless the 02 has the updated software as well. If they both have been updated then go with the cheapest.
fixedf50
How do i find out about the updated software, and if i do go with the 02 can i update the software at a dealer?
xerexabante
Car: '02 Infiniti Q45
'02 Nissan Maxima SE
The 04 has a different gear ratio and I believe heated/cooled seats. Check also if it has oil consumption issue. Get an extended warranty if you can.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Many differences, mostly in the electronics. Go with the 2004 if it has the better service history.
Read the sticky above.
Victor
Car: 1994 Infiniti J30T
The old rule of thumb is never buy the first year of a new model. Give them a chance to work the bugs outs. BTW, the 02 is listed as being more unreliable than other year infinitis. I assume the later the model of the third generation Q45s is the more reliable it will be if they fix any problems they find. But its a low production car so they might not have much money or incentive to re-engineer any problems they find. Can't find any reliability data on the later model so this is just a guess.It took them fhree or four years to fix the chain guide problems on the first generation Q45 models, and they never fixed the unreliable door locks or dimmer control or headlight relay problems of the J30
StarPD
Car: 2005 Q45
fixedf50 wrote:Newbie here planning on picking up an infiniti f50 anything I should look out for? I been debating on weather to get an 02 or an 04 any major different?
Get an '04.You'll be much happier with it. Faster, more reliable, and probably more goodies, plus lower mileage and less time for plastic/rubber components to age, not to mention suspension and trans being in newer condition. It will cost more in front, but less money for repairs, and less hassle with doing them, less depreciation and longer life.
