Hi Beam Hids????
All things Altima Coupe.
DReed86
Car: Altima Coupe 2008 SE 3.5 White CVT
So I reciently installed HID 8k low beams and I hate the fact that when I change to Hi Beam it looks like $hi!..... So I was mentioning to another NICO member that I was going to get another set for HI beams.
He said this was bad idea cause Hid's are not ment to be flicked on and off...
So im wondering if I do this, does that mean I just have to replace the bulbs every 6 months or so because it burns out or what????
Also is there a specific brand of HID I should get that maybe better for Hi Beams???
Thanks guys
AppleBonker
Not a good idea. HIDs have a long turn on time as they warm up. Turning them on and off isn't necessarily the problem, it's that you need to turn them on and wait a few seconds before they are actually useful. The only effective way to get HID hi beams is to rock bi-xenon projectors.
How often are your high beams on that this is a problem?
DReed86
Ok cool Ill look into the Bi-xenon lights... I just wanted to to know what the negatives were if I did Hi beam hid's it sounds like its not that serious so Ill probably do it Thanks for the info
