hi all
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
nexien
Car: infinity fx 35
i just recently got the ex 2008. first few weeks i was driving, as i was driving i put on the cruise control i did 100 on the highway. Then all the sudden it slowed down on me , i did not press the brake. then i tried to put back on the cruise again then it started blinking it wouldnt let me set the speed?
has anyone ever experienced about this? if so pls let me know
thank you very much
and secondly the trims around the windows on the driver sides start to come out i can put my finger there. it will be under guarantee>??
nexien
Car: infinity fx 35
XIS
Car: 08 Infiniti EX35 RWD
17 Infiniti QX30 Sport
You might want the dealer to check your cruise control when you bring it in for warranty on your window trim... Hard to understand all your steps and if you did something that would not allow the CC to continue...
what did you have the CC set to? Are you 100% sure you didn't hit the brake or the shifter? was it in D, DS or M?
jamesstock
Car: 2010 Liquid Platinum/Stone Journey
Diamond Cut IR Tint
I think the cruise control only works under 92mph or around that area (don't remember exactly).
nexien
Car: infinity fx 35
well i drove for a bit it was on regular position and sure i did not press the brake.
i tried to set at a lower speed then it worked for a bit then it started to blink it would not work. hmmmmm.... this morning i took it out for a spin then its fine a gain?
could it be there was direct sunlight? caused this cc not to work?
XIS
manual page 5-22
CRUISE CONTROL OPERATIONS
The cruise control allows driving at a speed
between 25 to 89 MPH
100 was too fast for the CC
Take it to the dealer and explain your scenario with the blinking lights and your speed under 89 mph...
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
