Hi, ive been reading these forums for quite sometime. Alot of you guys really know your stuff. Over the last couple of months with the help of your knowledge ive got enough parts to get me started on the turbo route.I have a nissan pintara/bluebird/altima (bluebird down here in NZ), with a ka24e motor. I have sourced a Z18et manifold and T3 type skyline Gtst turbo and whole pile of other parts. I am in the process of putting it together.
My question to you guys and girls, firstly
Is there a reason why you tap the oil return line into the bottom of the block. Could it be tapped into the up most edge of the sump?Is there an easy way out? Something i could 'T' into perhaps? (draining the oil, taking the sump off etc is a bit of a hassle).
Thanks again for sharing all your knowledge and experiance, i wouldnt have even considered taking the turbo route otherwise . Lucky i stumbled accross these forums.
