AG-M35 »
https://forums.nicoclub.com/ag-m35-u50500.html
Tue May 19, 2026 2:48 pm
This is a 2006 M35 base (2WD) / owned since new / VG maintenance schedule /
(2022) A couple years ago, finally at 120,000 miles, the valve covers started leaking and that was the first major repair / new aluminum covers (red), tubes, Spark plugs, PCV, new hoses, belts, but I didn't replace the belt idler bearings and occasionally have to put up with a bit of squeal on cold start (even tho the belts are at spec adjustment).
2023 - Alternator failed and was replaced by a rebuilt OEM unit - no issues thus far other than that long bolt coming loose once and having to reset with red lok-tite...
2024 - the bank 1 cam position sensor went away and it was replaced with an Hitachi unit. I have the other bank but it's a bit difficult to get behind the MAF...
Today, 123,875 miles/ car stalled in traffic, 95 degree heat, NO dash Lights, just stopped while at a traffic light. A/C fan running, radio on, Headlights on, no indication of anything amiss. Only happened to see tach drop to zero that made me aware of issue. Turned ignition off and tried reignition.... first attempt had no result. Turned everything off and tried again.... engine cranked a longer while than usual but started and we made it home. About a half mile from our place, the steering got heavy as if the belt had broken, but what does that have to do with stalling.... then I thought the alternator froze up and belt broke, but we got home....
In the driveway, I removed the shrouding from the front of the engine, started it and got out to measure the voltage at the battery, but there was only 12.3 volts and then realized it had stalled again, but the AC fan was still running and masking the still engine.
Restart and the alternator was measured out fine at 14.5 V, all the belts were intact, so the PS pump was apparently in good stead and nothing obvious mechanically. I connected an old Actron code reader and it revealed the P0335 code (Crankshaft Position Sensor A Circuit). So I have a spare Hitachi sensor and the FS manual, which describes the code, but cannot find the section on installing the new one....help?
Thx
