HHHEEEEELLLLLLPPPPPP!!
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
wytnte
hey guys, a mate of mie has a 84 720 king cab, he brought a cd player for it, how do we wire the old wires to new wires colour codes dont match? please help
PEZi
i got nothin man... without the advice of someone who hs a lot of experience in aftermarket speaker systems you may end up having to just re wire it all
dogred
Car: 1983 D720
Let me take a look at my service manual and I will get back to you.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
Just power the headunit and run all new wires for the speakers. At least I would.
dogred
Car: 1983 D720
the first color is the wire the second color is the stripethese wires are at the main harness
light green/white= speaker right sidelight green= speaker left sidelight green/red= speaker left sidelight green/black= speaker right side
red/blue= lighting -black/blue= groundbrown= power (after ignition switch)red/yellow= lightning +
I hope this helps out
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
Factory power for the radio = Brown, Ground = Black, Lighting = Red/ Yellow. Run new wires to the speakers, it will solve all the problems.
86 720
Car: 1986 720 4cyl Standard Cab
flinterman2000 wrote:Factory power for the radio = Brown, Ground = Black, Lighting = Red/ Yellow. Run new wires to the speakers, it will solve all the problems.
X2...
I would just run all new wires for it all...
wytnte
to run all new wires, where will i get the power and the source of ignition from? thanks!
turbojunker
Car: 79 510, 81 720, 72 510-RIP
wytnte wrote:to run all new wires, where will i get the power and the source of ignition from? thanks!
I used the factory wires for power, memory, and ground, and only ran new speaker wires.
dogred
Car: 1983 D720
I did the same, but if you cannot use the factory harness you can run the new wire from the where the brown wire hooks up at the fuse block. The incoming wire is white/red, this is power after the ignition. Brown is after the fuse and white/red is before the 15 amp fuse.
I highly recommend that you use the stock harness rather than creating a wiring nightmare for your self later.
The memory wire you will have to run to the battery. The ground can be put on any bare metal screw close to the radio. You could redo the harness by finding a four wire male and female plug that will fit together and hooking them up to the power memory and ground wires and running the speakers straight. If you do this cut the brown, black/blue as close to the stock harness as possible. Then put them into the new plug.
flinterman2000
dogred wrote:The memory wire you will have to run to the battery. The ground can be put on any bare metal screw close to the radio.
Not necessarily. There are continuously live wires at the fuse box. Use any tester to locate the live wire. A tester comprises a 2 wire socket and a bulb. Ground one of the wires and contact the wires on the fuse box with the other with the vehicle off. Once the bulb glows thats a live wire.
wytnte
cheers guys, we will give it a crack. thanks again
Return to “Datsun 720”
