I'm not sure where in the bay area you are but you can try a performance shop. They do plenty bolt-on exhaust and turbo car work so they should have no problem getting the cats off.PostalsQ wrote:I tried. Unsuccessfully. I researched it. Noticed 1 bolt was best to remove from under the hood. Removed the TB tube. Couldn't use 1/2 inch. Didn't have enough extensions. Used the next size down. I kept slipping on the bolt. Didn't want to strip it. Tried several times. So I just gave up. Need to find someone to help me out. Muffler shops around me refuse to install in fear of CARB.
