heyyy pleaseeeee can sombody help me..
mauri s13
Car: 240sx silvia s13
well 3 weeks ago i was just trying to drift in my 240 and then the car just turn off and didn't start anymore. the fuel pump was working and i had spark. then i buy the cas because a mechanic told me that was the problem. but wen i put the new cas same thing didn't start but now the fuel pump was not working and i had no spark. my ignitor chip its working so i don't know what the problem is. pleeaseeee HEELLPP!!one more thing... i check my ecu and it's not getting power. my fuel pump fuse its working but the next one its the eccs fuse its no getting power when i turn the kkey on. help
slidestyle69
Car: 92 s13
Is your wiring made up with butt connectors??? or sodlered??
mauri s13
i think its soldered. do you think its the wiring the problem?
slidestyle69
Car: 92 s13
well if its butt connectors then with movement of ur car drifting might had made a loose connection but yea im sure it wiring, if u say the fuel pump comes on and the coils are firing. Tell You what check your point of the wiring harness where it has been spliced for the motor and that would be found Where the battery tray is and also take the kick panel off the passenger side and check them first check and see how your harness has been made up. If its butt connectors then slightly pull on each side of every connection to make sure they are tight, replace any connections that are loose( you can burn your car down if that isnt fixed) and if ur soldered then double check and make sure everything is good and post back, ill be at work till 9pm tonight. ill be watching this to see if u post back
mauri s13
look im going to explain you how this happen.. the day i was drifting the car just turn off.. but the fuel pump was working and the car had spark so I took my car to a mechanic and he told me that the injecctors were not reciving any signal to open..so the mechanic told me to change the CAS so i buy oneand i put the new CAS and then the fuel pump was not working and i had no spark. so I don't know what it is.. it can be the wiring but the day i was drifting and the car just turn off the fuel pump was working and i had spark. and what do you mean saying "you can burn your car down if that isnt fixed"?? im sorry i don't speak a lot of english.
slidestyle69
Car: 92 s13
what i meant was if ur running butt connectors and there is a loose connection it could cause a fire. but i dont really understand how u had spark and fuel and now u changed ur cas there is no spark and fuel but the first thing that isnt right is where ur mechanic told u to change the cas bc your injectors weren't getting enough power. You said your ecu isnt working. two things could be wrong here. 1..loose connection and the ecu isnt receiving power bc of it2.ecu is fried due to a wiring issue.
like i said check ur connections and see how ur harness is made up. and also if ur connections check good then take the back off ur ecu and check for burnt circuits.
mauri s13
okey thanks for the help I'm going to check my harness to see if its all the conectors right. or as you said take the ecu and check for burnt circuits. i will tell you if it was some of the problems you said. thanks man.
mauri s13
and how can I check if my ecu is fried due to a wiring issue??
schanne
Car: 93 Hatch-Sr20
Can we say "new mechanic"?
mauri s13
finally.. my car its working... hey slidestyle69 thanks for the help.. it was a burnt circuit as you said.. thanks man.. i really appreciate your help.
