texasoil »
https://forums.nicoclub.com/texasoil-u1000.html
Sat Jul 22, 2006 2:10 pm
Adjustable tension rods? Why--simply 'slot' the 3 bolt holes in the tension arm attachment sub-frame-the 3 that bolt the subframe to the frame. MY q45A'S each have those slotted OEM. To adjust caster, simple measure it, figure out how much you want to move it, remove tension arm, loosen mounting bolts (gotta remove the arm to get to the rear bolt), and move the mounting bracket forward the desired amount, Reinstall the tension arm -I used an inexpensive 'block and tackle' to pull the lower control arm forward so tension arm bolts would slip in). EASY, MIANTAINS OEM INTEGRITY, ADJUSTABLE, RETAINS OEM SHOCK ABSORBTION
