ricebike »
https://forums.nicoclub.com/ricebike-u5064.html
Mon May 24, 2004 4:42 pm
detser122,
it's up to u; i told my lil bro when he 1st got his 91 eclipse to concentrate on the preventative maintenance 1st before upgrading...
but he went to upgrade his stereo, install glow-gauges, strut bars, paint interior trim pieces, car seat covers, etc...
...while i worked on his oil change, check/replace plugs.wires.cap,rotor, o2 sensor, remove that intake resonator, transmission fluid/filter change, valve cover gasket, throttle body valve cleaning, check/adjust idle/timing...checked out suspension/brakes/driveline... he got a tore boot on the driver side axle <so he's gotta save up for a replacement>
he's a young guy w/ no other responsibilities so I guess he can make his car "look pretty" as well as keep his car maintained... if u r in the same boat, go for both the lsd swap & impending brake job... a brake pad change isn't too dificult anyways.
ya, i need an lsd as well, but i got priorities 1st...
Edit: you're in a "hot zone" so get some kill switches installed as well...
