pheonixS13KA24 »
https://forums.nicoclub.com/pheonixs13ka24-u5201.html
Thu Apr 08, 2004 7:35 am
What's up again guys... I still have yet to pass my emissions inspection in Missouri, and I only have 3 days until my temporary tags expire! When I start the car cold, it jumps, stumbles, and almost turns off; then I hit the gas, it does it once more, I hit the gas, and everything runs fine. Temperature sensor? The previous owner said it wasn't Ohming out correctly. My car also gets fairly bad gas mileage for its condition. Here's what I've done to my car and the emissions results:
1.) Replaced distributor cap and rotor2.) Replaced spark plugs and wires with Bosch Platinum3.) Checked Ohm resistance on all fuel injectors: All were approx. 14.8 Ohms (computer at BP said it should be around 13 Ohms)4.) Checked compression on all four pistons... 179 PSI on each piston across the board!!! Wow, I couldn't believe this. Pretty close to perfect! I mean, I do have 100,000 origional miles on it...5.) Used a concentrated fuel system cleaner... Car runs better but doesn't pass emissions!6.) Used full tank of premium gasoline during the test.7.) Replaced fuel filter
So, the emissions test said this:
Hydrocarbons: My reading: 2.4221 grams/mile Standard: 0.8000 grams/mileCarbon Monoxide: My reading: 77.7062 grams/mile Standard: 15.0000 grams/mileOxides of Nitrogen: My reading: 1.9116 grams/mile Standard: 2.0000 grams/mileCarbon Dioxide: My reading: 380.2988 grams/mile Standard: No standard
Somebody HELP!!! I can't figure out what's wrong... I'm pretty new at this "tuning" stuff. Could it be the catalytic converter? How about the O2 sensor? I need help guys. Thanks!!!
