TalkPrt wrote:Sure changing cam drive chains only adds ~~$100 in parts but the extra 11-14 hours of book labor........makes them a $1,000 item.........but you do get your valve covers reseal [a normal $500 item].......you could change plugs simultaneously for only the cost of plugs.
1)As clarification, are you saying that the cam drive chains should be replaced at the same time when the drive chain guides are replaced in order to avoid repeat labor cost because the scope of work overlaps? 1b) So this basically means only an additional $100 in damages, plus cost of new plugs, right?
2) that makes it inefficient to search for the topic you really want. [/QUOTE]
1)No. No need to replace chains at that time. Chains last essentially life of car, no cases known to us as a group were chains failed unless due to broken/failed guides1b) No, lots of addtional labor costs will be incurred, in addtion to parts costs.2) You should have seen our old yahoo groups format , from where we all came to here.Individual posts interupted by ads.
Fred...
PS: Welcome to the group..:jazz:
