Doogz »
https://forums.nicoclub.com/doogz-u5748.html
Wed Apr 14, 2004 2:37 pm
The swaps will be exactly the same, with the exception that the sr has different radiator inlet/outlet locations. As far as turbos, the sr turbo is slightly better and i believe they both have the same stock boost but i could be wrong on that one.
If you want SR, then go SR...don't let something simple like PS lines change your mind, especially since you'd have to do the same thing with either engine.
