hey people need a hand plz !!!!
bigboy25
Car: F150 fx4 off road 2005 and a 240sx 89
i need the wiring diagram for the winshield washer pump or maybe just the wire color code because the previous owner of my 240 89 just cut everything off.
and also i got a problem with my cluster i took it off the dash but my baterie was not disconect and when i came to put my back nothing was working on it no light no gauge nothing and the speedometer gauge was a the end pass the limit.
need somebody to save my life plz thanx
boriquaS13
Car: 92 240sx
Do you have access to a voltmeter or test light, check for power when you push the washer switch. Then wire it up if you work the washer and you here it run but no water comes out then reverse the polarity. As for intrument cluster did you even plug it back in, if so check your fuses. You could also have a bad connection at the back of the cluster. Hope this helps.
bigboy25
ttt
bigboy25
really need help boys and girl
