hey just got an sr red top ,i want to make a 350 whp motor
mxkilla450
i got an sr red top its all stock i want to make a 350whp motor.please leave out the [throw a huge turbo and call it a night]set ups . if you guys can help it'd be great thanks
david200095367
Car: 91 fastback 93 coupe w/s14 sr20det 98 s14 kouki
bigger turbo, injectors, tune and you got it. oh yea "search box" is your best friend.
240_SeX
Car: 1992 240SX SE
david200095367 wrote:bigger turbo, injectors, tune and you got it. oh yea "search box" is your best friend.
x2
You should get around a 550cc injector, at least a safc or something comperable or a rom tune, and whatever you choose for a turbo, the t25 wont do it, you can make around 300-320 if you really push a t28. its all in what you want/can spend.aslo cams will make your trip to 300+ a little eaiser.
johnnyappleseed
Car: s14 240sx with s13 sr20det
def agree with 240sex. the gt28 is a good turbo to get you there.
jfryjfry
Car: 1991 180sx
don't forget exhaust, a good fmic, good fuel pump (255lph), afpr, a bigger maf (z32), boost controller, and check your afr's
Slammed95S14
Car: 2001 R50
Max out your boost controller, and run a AFR of 15.
HA!
