nissandoms47 »
https://forums.nicoclub.com/nissandoms47-u53256.html
Sat Mar 24, 2007 4:23 pm
I cant find the detailed link that tells everything but ill sum it up.
for the rear shocks
7/8s socket or impact for the top nut, 19mm and a 17mm for the lower bolt
for the front struts
remove the swaybar link bolt, 19mm i think, this one can be a pain if its rusted
2 bolts holding the knuckle to the strut, 19mm and 17mm
1 bolt under the rubber boot on the top of the strut, 19mm? Just give it a few turns, do NOT totally remove the nut
3 bolts holding the top of the strut to the tower, 14mm
after that maneuver the strut around and out.
compress the coils with a coil compresser
remove the top nut and remove the coil
reinstall in reverse order
