Hey I need some wheel help, if anyone can give me some insite it would be great
Morb
Car: 1990 Nissan 300zx N/A 5spd
Hey i really want to buy a set a ADR Battle Exe 18" for my 300, i know the bolt pattern is 5x114.3 Offset +35. My question is will these work 18x7.50 5x100/114.3 i think the offset is 42, those number are very different, but the websites i keep finding these wheels on says the will fit the car, now am i going to have to buy wheel spacer's or what? any idea's or any info anyone has let me know. Thanks.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
+35 is definitely the highest offset I would ever put on a Z32, and depending on how well they fit, I might get spacers to flush them out with the fenders. Also, If you're lowered, you'll most likely need to roll/pull the fenders to prevent rubbing, them being 18" rims.
Morb
The car isn't lowered as of rite now, i don't plain on lowering the car anytime soon, if anything im just going to beef up the suspension, IE better shocks and struts. But i will be going to a lower profile tire with a stiff sidewall to keep from rolling the tire's... All im wondering is if the rims will fit on the car or not, or if im going to need a wheel spacer, i really like and want these wheels, but if they wont work then i have a back up plain. I can always go down to a 17" if 18"s are going to be to much, and just lower the car around the tires.
Ace2cool
Well, just FYI shock=struts, and if you are going for more aggressive springs, then you'll have to go lower, unless you do a coilover setup that allows for stock ride height while maintaining an aggressive spring rate.
But from strictly specs, yes the wheels will fit. They might not be flush with the fenders, i.e. "sunken in" but yes, they will fit. Shouldn't be any clearance issues with the suspension and will clear the brakes fine.
Morb
Ok thank you. appreciate the info.
Ace2cool
No prob man
nevertheless
Car: 1993 240sx hatch
1995 Nissan D21
They will look like s***, I wouldnt go above +20 especially for the rears.
Morb
Ok then tell me what size should i get, that will give me an aggressive stance, that will flush out the wheels with the wheel wheels, and will look good IE. not to small or to big.
I realize the car already has an aggressive stance, i would like to enhance it with some wheels..
Im looking for help, not criticism but hey ill take whatever i can get at this point.
This is my first Z and im not going to rice it, i want a clean car.
Morb
how about these, will these work? 18X8 5-114.3 30GBM?
http://www.discounttiredirect....&rw=8
nevertheless
1995 Nissan D21
No, those belong on a honda too, Check out Rimtuck.com and you can search for your vehicle.
car nut
Car: GT500.
nevertheless wrote:They will look like s***, I wouldnt go above +20 especially for the rears.
With that width, I'd have to agree. Go wider.
