Mikey178 »
https://forums.nicoclub.com/mikey178-u136238.html
Sat Aug 29, 2009 4:01 am
Just a thought but may be worth checking the fader (Front or Rear) and balance (Left and Right) settings, have those been changed accidentally?
Connection at the speaker may be loose. Id say check this next.
If the above 2 suggestions don't work, check to make sure the speaker is not damaged or burnt. To check it would be a little more involved, you'd have to disconnect the speaker and connect it to the right side and then play some sound and see if its still plays with little to no sound or if it plays normal. If it plays normally then you know you speaker is good and that the problem is either with the connector, wiring or the headunit itself.
